1990 Mazda Miata overheating
160,000 MILES • 4 CYL • 2WD • MANUAL
DR_TPB
leak in backside of engine cant tell were it is comming from no water in the oil
Aug 25, 2008 at 10:25 AM
  • 31,937 POSTS
HI there,
You will need to get a cooling system pressure test done, this will help locate any coolant leak, if there is coolant leaking from between the engine & transmission and you can't see any external leak you may have a leaking core plug behind the flywheel, start here.
Mark (mhpautos)
Aug 25, 2008 at 10:40 AM
