1990 Mazda Miata Clutch
1990 MAZDA MIATA
143,000 MILES • 4 CYL • 2WD • MANUAL
MSINGER426
I suddenly began having problems with my clutch. The pedal bottoms out very easily. The transmission will go into gear but, upon stopping, the clutch will not disengage the transmission from the engine and the stick shift must very forcibly be yanked out of gear in to neutral. I have just replaced the slave cylinder and bled the system with no luck. What should I do next?
Aug 27, 2008 at 6:37 PM
  • 31,937 POSTS
Hi there,
I would be checking the master cylinder next.Check for fluid out the rear at the push rod under the dash.
Mark (mhpautos)
Aug 27, 2008 at 7:23 PM
