1990 Mazda Miata
MARTINY43
Engine Performance problem
1990 Mazda Miata 4 cyl Two Wheel Drive Manual
my car run like is on the choke all the time. on idel it run at 1900rpm. the computer said juste the selanoid valve is broken. i change de selanoid valve but the problem is again there. what i can check on my car for this problem? thanks and sorry for my english. i speak french usaly
Apr 4, 2008 at 5:39 AM
BLACKOP555
  • 10,386 POSTS
when you replaced the IAC module, did that fix the idle for a little bit? or did that not fix it at all?
Apr 4, 2008 at 12:39 PM
MARTINY43
[quote:46aa5d043f="blackop555"]when you replaced the IAC module, did that fix the idle for a little bit? or did that not fix it at all?[/quote:46aa5d043f] its dealer mazda said me change de selenoid. he dont talk to me of idle. what do you want to say by fix the idle for a little bit? the idle run behind 1500 and 2000rpm. befor the problem the idle was 900rpm.
Apr 7, 2008 at 8:21 AM
BLACKOP555
  • 10,386 POSTS
when the solenoid was replaced, did the vehicle run good for a little bit?
or did the new solenoid not fix the problem at all?
Apr 7, 2008 at 11:45 AM
MARTINY43
[quote:6f1b9b8781="blackop555"]when the solenoid was replaced, did the vehicle run good for a little bit?
or did the new solenoid not fix the problem at all?[/quote:6f1b9b8781]juste try to run good, but not 2 second. but when i come out my car after the winter, its run good some day ( between 1 day and 1 week)
Apr 10, 2008 at 7:38 AM
