1999 Mazda b4000 GAS GUZZLER
70,000 MILES • 6 CYL • 4WD • AUTOMATIC
OWENIE
  • 5 POSTS
My 1999 Mazda B4000 4x4 gets 380km to a tank and sometimes sounds like it has a vaccum cleaner under the hood niose is coming from the air intake plentum.I changed the air filter,plugs no differents.
Sep 4, 2010 at 8:54 AM
MERLIN2021
  • 17,250 POSTS
Check the plenum for cracks, unmetered air intake will cause problems with air fuel mixture. Check gasket at MAF sensor and tube ends as well. Use spray throttle body cleaner and spray all vacuum ports and hoses and air intake, a leak is found when the engine idle changes. Keep spray away from hot exhaust! It is flammable!
Sep 25, 2010 at 4:30 AM
OWENIE
  • 5 POSTS
I tried the spray trick idle NO different. I tried the screw driver againt the ear to see if the injectors were ticking and all 6 where ticking.Any other suggestons Merlin 2021.
Sep 28, 2010 at 8:01 AM
MERLIN2021
  • 17,250 POSTS
Have you tried to read any stored codes? Is the check engine light on? And if you have a clutch type cooling fan, the extra noise and engine load may be due to a defective fan clutch.
Sep 28, 2010 at 2:50 PM
OWENIE
  • 5 POSTS
I have replaced my Clucth type cooling fan assemble 4 weeks ago .It still only does it once in awhile and is still Very hard on Gas . Oh mileage is 164,400KM. About two years ago when I had my mechanic look at it had codes 171 &174 lean fuel/air codes both banks. HE cleaned the Oxgen Sensor and cleared thecodes ???.No codes came back ?? But still hard on GAS. Please help me try to slove this HEADACK!!!
Sep 30, 2010 at 6:03 AM
MERLIN2021
  • 17,250 POSTS
The KM's don't mean much to a guy from Boston, Miles per gallon! Lean codes would probably vacuum leaks and or weak fuel pump, test the fuel pressure.
Sep 30, 2010 at 3:55 PM
OWENIE
  • 5 POSTS
TO merlin 2021 I found the problem with the vaccum cleaner sound under the hood.It was the Idie Air Control Vavle,I will replace it.To get km. to miles you divide by 1.6 so 165000km is 103125m. I will let you know if this gives me any better gas milage etc.
Oct 17, 2010 at 1:32 AM
MERLIN2021
  • 17,250 POSTS
Good work! Usually in my vacuum leak answers I do say to check/rplace that if no leaks are found, sorry for not mentioning it here!
Oct 18, 2010 at 3:47 PM
