how do you change the fuel filter on this type of truck?
Oct 14, 2010 at 3:16 AM
✓Experienced Mechanic
Relieve the system pressure. See FUEL PRESSURE RELIEF.
Disconnect the push connect and hairpin clip fittings. See PUSH CONNECT FITTINGS or See HAIRPIN CLIP FITTINGS.
Remove the fuel filter from the bracket.
If necessary, remove the nut and the bracket.
Install in reverse order of removal.
