2001 Mazda b3000 Transmission sometimes will not go after h
87,000 MILES • 6 CYL • 2WD • AUTOMATIC
BROCKEY3
On occasion when I have to come to a rather quick stop the transmission appears to be in neutral when I attempt to move after the stop. A shift of the lever into reverse usually brings a "clunk" and then when I shift back into drive the truck will go again.
Can you give me some advice re: this issue? The fluid seems to be OK.
Jan 19, 2010 at 11:20 AM
  • 31,937 POSTS
Hi there,
Thank you for the donation,
I feel that this is an internal pressure problem with the transmission, to diagnose this correctly you will need to get a transmission specialist to do a test and report for you, as they will have all the specialist equipment to test this transmission throughly, start here.
mark (mhpautos)
Jan 19, 2010 at 4:00 PM
