2000 Mazda b3000
ALBERTABENAVIDES
2000 Mazda b3000 Two Wheel Drive Manual
i push my brake in all the way down and it sound like air is being push out i already bleed the lines and it still doing it
Aug 4, 2010 at 7:29 PM
BLUELIGHTNIN6
  • 16,542 POSTS
check for leaky brake lines and also check fluid in master cylinder. if brake lines are good then check vacuum hoses at brake booster. if all good then master cylinder most likely has internal leak.
Aug 4, 2010 at 7:51 PM
