1999 Mazda b3000
1999 MAZDA B3000
150,000 MILES • 6 CYL • 4WD • MANUAL
HOPSTER
just replaced the clutch and the abs light is on, no speedometer or odometer. I am hearing a funny noise from the drivers side wheel well, What went wrong?
Aug 27, 2009 at 3:02 PM
BLUELIGHTNIN6
  • 16,542 POSTS
sounds like you may have accidentally knocked a wheel speed sensor loose. this is what controls your ABS and speedo readings. check in the wheel well that you hear noise to see if any connections are loose.
Aug 27, 2009 at 6:12 PM
