1998 Mazda b3000 Headlights will not turn on
175,000 MILES • 6 CYL • 2WD • MANUAL
FDEALING81
Headlights will not turn on via 3 position selector switch. Parking lights are okay. Highbeams will flash by pulling turn signal stalk towards driver, they will not stay on when stalk is pushed forward. Both headlamps and the headlight switch have been changed---no luck. Fuses check good. Is there a headlight relay? Any other ideas? Thanks.
May 29, 2010 at 9:58 AM
BLUELIGHTNIN6
  • 16,542 POSTS
could be faulty multi function (turn signal) switch. do you have daytime running lights?
May 29, 2010 at 10:15 AM
