1998 Mazda b3000 clutch
BRION EDMISTON
Transmission problem
1998 Mazda b3000 6 cyl Four Wheel Drive Manual
the clutch pedal is very soft and doesn't engage until almost the bottom of the pedal. The clutch fluid level is where it should be. If you pump the clutch, you can get it to shift into gear. Please advise. Is there any adjustment that can be made?
Aug 26, 2009 at 11:13 AM
  • 31,937 POSTS
Hi there,
I would first re bleed the system, check for any signs of seepage under the slave cyl boot and also the master cyl, there is no adjustment on the clutch, a soft pedal is normally the sign of air in the system.
mark (mhpautos)
Aug 26, 2009 at 11:22 AM
