1995 Mazda b3000
DAVID HAGOOD
Drive Train Axles Bearings problem
1995 Mazda b3000 6 cyl Four Wheel Drive Manual
pulled motor out. installed new clutch disk. reinstalled engine. everything lined up well. put 2 bolts in bell housing. got them snug. heres the problem..... clutch pedal will not depress. it is pressured up high on the pedal. does not feel like the clutch is working. like hitting the brake pedal. what is wrong?
Oct 9, 2008 at 7:26 AM
DOCFIXIT
  • 18,828 POSTS
Did you install new pressure plate and throwout bearing.? Bearing maynot be placed correctly and will not slide on sleeve.
Oct 9, 2008 at 7:42 AM
DAVID HAGOOD
[quote:d0c9b539d8="david hagood"]Drive Train Axles Bearings problem
pulled motor out. installed new clutch disk. reinstalled engine. everything lined up well. put 2 bolts in bell housing. got them snug. heres the problem..... clutch pedal will not depress. it is pressured up high on the pedal. does not feel like the clutch is working. like hitting the brake pedal. what is wrong?[/quote:d0c9b539d8] i pulled motor back out and cannot find anything wrong. Are you supposed to bleed the slave cylinder upon reinstalling?
Oct 9, 2008 at 9:54 AM
