1994 Mazda b3000 New clutch master and slave cylinder
1994 MAZDA B3000
211,000 MILES • 6 CYL • 2WD • MANUAL
JEREMYSHANSEN
I just replaced my clutch master and slave cylinders and the line on my 1994 Mazda b3000 and now cant get it to billed any presser at the pedal to engage the clutch please help
Sep 28, 2010 at 11:13 AM
BLUELIGHTNIN6
  • 16,542 POSTS
did you bleed system?
Sep 28, 2010 at 12:11 PM
JEREMYSHANSEN
Yes I have I have put on 3 different masters 2 slaves and 2 lines all new and still wont billed presser when bled
Sep 28, 2010 at 3:03 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Try this, go to the inside of the vehicle and unhook the clutch rod. Then remove the safety switch to get access to the snap ring on the master cylinder and remove it. Be sure the tank is full of fluid. (Put a rag under the master inside the vehicle to catch fluid) Slowly pull the clutch rod out and the air will come out of the master. When the air is out carefully push the rod back into the master
Sep 28, 2010 at 3:07 PM
