1994 Mazda b3000 clutch/bleeding
BONNIE WEBB
1994 Mazda b3000 6 cyl Two Wheel Drive Manual
We bled the brakes after installing a new cllutch and had to do it again. It has actually been done 3 times.
No fluid is leaking out but the clutch won't work. Two people said there is an air bubble in the line. What do you do to get it out????
Mar 21, 2009 at 12:56 AM
T-ROY1
fill the resavoir with brake fluid, open the bleeder valve on the transmission, taking care to keep fluid in the resavoir. watch for air to come out of the bleeder valve. do not depress cluch pedal during this process, it is gravity fed.
Mar 31, 2009 at 10:36 AM
