1994 Mazda b3000 Check engine light comes on - failed emiss
245,000 MILES • 6 CYL • 2WD • AUTOMATIC
SIRDINO
Hey guys:
The check engine light was staying on in my 1994 Mazda B3000 (3.0 V6) and it failed on the HC and NOx portion of the emissions.
Niether I nor an auto parts guy are able to find a module for connecting a diagnostic tool to get the codes. I have been scouring the internet but I cannot find a way to get the "blink codes" from the dash panel. Would anyone happen to know how to do this?
FYI: I replaced both O2 sensors, the egr valve, the pcv valve, a bad vaccum line that goes from the PCV to the charcoal canister, changed the oil and filter... the truck failed a second time with slightly higher numbers.... I wonder if I got the left side and right side O2 sensors mixed up.... the part description did not specify which was which..... maybe the valve seats are worn?
Jul 6, 2010 at 4:04 AM
  • 75,988 POSTS
You need to find the check connector and jumper TEN to GND to flash the codes
Jul 6, 2010 at 4:40 AM
SIRDINO
Thanks. I will check it out tonight.
Jul 6, 2010 at 4:53 AM
