1993 Mazda b2600 Wont start after cleaning engine
RICK GALASYN
Engine Performance problem
1993 Mazda b2600 4 cyl Automatic
Hi
Cleaned engine and engine compartment, Used a water rinse.
Engine won't start.
Checked and dried all the obviouse (rotor, connectors, ...
..) no help.
Now I suspect water got into the opening of what I think is the ambient air pressure sensor (control).
Got any help?
Rick
Mar 21, 2010 at 9:04 AM
  • 75,988 POSTS
Hi Rick Galasyn, Welcome to 2carpros and TY for the donation
What you need to determine is if its getting fuel or spark-you need to establish this. Do below and come back with some results
Mar 21, 2010 at 11:57 AM
RICK GALASYN
Hi Rasmataz
Do not have Hi-V out of the coil.
Do have twelve volts in.
Rick
[quote:fd83852d89="rasmataz"]Hi Rick Galasyn, Welcome to 2carpros and TY for the donation
What you need to determine is if its getting fuel or spark-you need to establish this. Do below and come back with some results we start here
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it[/quote:fd83852d89]
Mar 21, 2010 at 12:19 PM
  • 75,988 POSTS
No secondary surge voltages: Continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Mar 21, 2010 at 12:24 PM
