1993 Mazda b2600 water leak
202,500 MILES • 4 CYL • 2WD • AUTOMATIC
F TRUEMAN
I have a water leak under the intake manifold high up on the block. It only leaks when the thermostat is open & the engine is running.
Jun 25, 2010 at 3:10 PM
  • 31,937 POSTS
Hi there,
This will have to be pressure tested hot and inspected with a mirror and a good light, you will have to identify what is leaking, a hose or the manifold gasket or head gasket, start here.
mark (mhpautos)
Jun 25, 2010 at 3:35 PM
