1992 Mazda b2600 will not accelrate
1992 MAZDA B2600
200,000 MILES • 4 CYL • 2WD • MANUAL
FIELD MAN
  • 7 POSTS
the truck starts and idles fine but when you accelrate it tries to choke it self down
Oct 29, 2010 at 12:51 AM
Lack of acceleration,chugging,hesitating,jerking,bogging,misfiring etc. could be caused by one of the following below
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Knock sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it
Oct 29, 2010 at 11:23 AM
