1991 Mazda B2600 engine doesnt start
MAZDA B2600
  • 1991 MAZDA B2600
  • 4 CYL
  • 4WD
  • MANUAL
  • 206,000 MILES
Ran good than it wouldnt start changed the computor and it ran fine again now 1year later tonight it wont start?
Friday, October 22nd, 2010 AT 12:34 AM
Cranks but no start condition-do below to determine if it's a fuel or spark issue:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, Do you hear the fuel pump come On when you turn key on? If not check fuel pump fuse and fuel pump relay if so, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Sunday, October 24th, 2010 AT 11:38 PM
