1990 Mazda b2600 Runs erratic and dies
90,000 MILES • 4 CYL • 2WD • MANUAL
BEACH2916
As soon as it started (from cold). idled erratic(1200 to 2000 rpm's) and if you accelerate it tries to die. Then it would accelerate with out dieing. Then stopped running and won't start.This all happened in 5 min.
I've had the computer replaced and it's run great for 6 mo. don't think it's an ignition problem. I take immaculate care of this truck. HELP!!!
Oct 21, 2010 at 2:06 PM
SERVICE WRITER
  • 9,123 POSTS
Need to go to the basics, checking fuel pressure, see if there is spark getting to the plugs and or checking compression/timing.
A little starting fluid may help to eliminate or confirm fuel presence and spark presence if it starts and runs for a moment.
Oct 22, 2010 at 12:28 AM
