The engine is missing and I have a loss of power and gas is coming out of the exhaust. Thinking I have an ignition system problem I replaced the spark plugs, wires, coil, distributor cap, and rotor. I also checked the compression it seems to be good. There is a significant amount of gas coming out of the exhaust. Enough to leave a large puddle after 30 seconds of idling. Could the fuel injection be stuck wide open? Could the igniter be bad? Is there any way to check the igniter?
Mar 19, 2010 at 3:48 AM
