1989 Mazda b2600
168,000 MILES • 4 CYL • 4WD • MANUAL
PWELLS87
i have a 89 mazda b2600 it will crank an run for about a minute then go dead an will not crank back up its rollin over but it will not start i have changed the plugs an plug wires the fuel filter an fuel pump an i still dont no what is wrong with it
Feb 18, 2010 at 4:51 AM
  • 75,988 POSTS
Do you have spark if so and you got the correct fuel pressure-check the valve and ignition timing.
Feb 18, 2010 at 5:12 AM
