2003 Mazda b2300 truck will not start
2003 MAZDA B2300
LPASCUAL
Engine Mechanical problem
2003 Mazda b2300 4 cyl Two Wheel Drive Automatic
I turned key and makes no sound not even a click.
Tested starter, it works. Tested fusible link from battery to starter, its good. Battery is also good.
Is there anything else I should try?
May 4, 2010 at 9:07 PM
Check and test fuse no.24 7.5amp,starter relay,transmission range sensor and ignition switch.
May 5, 2010 at 8:06 AM
