1997 Mazda b2300 flasher/turn signal switch
1997 MAZDA B2300
KANE.SHIMEK
Electrical problem
1997 Mazda b2300 4 cyl
I cannot locate either the flasher or the turn signal switch. I have looked under the entire dash and behind instrument panels (disassembled all).
My turn signals will not even come on--not just not flash.
Should I be even looking for the flasher?
Where do I look specifically?
I read online that in Mazda's it is a combo flasher/switch and I followed the manual for a Ford Ranger and the flasher IS NOT where it says it is.
HELP!
Mar 24, 2010 at 1:26 PM
BLUELIGHTNIN6
  • 16,542 POSTS
the turn signal switch is the actual switch you use to turn on and off the signals.. the flasher is located behind the left side of the dash, on the instrument panel fuse box. also check the fuses as well..
Mar 24, 2010 at 1:57 PM
