transmission control module
170,000 MILES • 4 CYL • 2WD • AUTOMATIC
QUINTANA078
where is the transmission control module located?
Dec 16, 2009 at 2:46 PM
KHLOW2008
  • 41,812 POSTS
Hi quintana078, Thank you for the donation. Transmission and engine control unit are integrated into one unit, Power Control Module in the diagram.
https://images.2carpros.com/forum/automotive_pictures/192750_EngComponent96B2300Fig01_1.jpg
Dec 17, 2009 at 1:38 AM
QUINTANA078
the spot in the diagram that you pointed out... the part the store gave me is different... the actual reading on the diagonastic reads... P 0761 shift solenoid c performance or stuck off....
Dec 19, 2009 at 11:17 AM
KHLOW2008
  • 41,812 POSTS
What you are referring to are the shift solenoids and they are located on the automatic transmission valve body inside the transmission. Item 96 to 99 and 102 + 103 in the diagram.
https://images.2carpros.com/forum/automotive_pictures/192750_ShiftSolenoids96B2300Fig25_1.jpg
Dec 19, 2009 at 1:21 PM
