1996 Mazda b2300 hard 1st and R
1996 MAZDA B2300
106,000 MILES • 4 CYL • 2WD • MANUAL
BAM87
IVE RECENTLY BOUGHT AN 96 MAZDA B2300 4SLY 5 SPEED MANUAL, AND HAVE/HAD TROUBLES SHIFTING INTO FIRST AND REVERCE FROM AN STOP POSISTION.. THINKING, THAT I HAD AIR IN MY MASTER SYLENDER, I REMOVIED THE HOLE SYSTEM FROM MY TRANNY AND BEGAN TO BENCH BLEED THE LINES.. AFTER REASEMBALING, I FOUND AN SOFT CLUCH PEDDLE!!!
READING OTHER REVIEWS, I BEGAN DRIVING AROUND MY BLOCK TO BULID PRESHER BY DRIVING!!! "NOT RECAMENDED" AS I DROVE FARTHER DISTENCES, MY CLUCH BEGAN TO SEEM NORMAL AS IF IT WAS FIXED!!
LITTLE DID I KNOW 100+ MILES LATER, IM BACK TO THE SAME PRADICTAMENT.. HARD/NO FIRST OR REVERCE..
IS THEIR ANY-THING THAT CAN BE CAUSING MY TRANNY NOT TO ENGAGE? OR DO I YEST NEED AN NEW CLAVE SYLENDER??
ANY HELP WOULD GREATLY BE APRESHEADED!!! -BAM
Nov 7, 2010 at 10:13 PM
KHLOW2008
  • 41,814 POSTS
Hi bam87,
The master or slave cylinders could be failing resulting in insufficient trvel of the clutch fork to release the clutch.
If pedal pressure is felt very low, check the master cylinder push rod to pedal adjustment/free play. Adjust if necessary.
Nov 8, 2010 at 3:43 AM
BAM87
THANK YOU VARY MUCH FOR YOUR FAST REPLY!!! ILL TRY TO AJUST THE FREE PLAY, AND POSIBLY LOOK INTO REPLACING THE MASTER/SLAVE.. -BAM
Nov 8, 2010 at 3:44 PM
KHLOW2008
  • 41,814 POSTS
You're welcome. Let me know how it goes.
Nov 8, 2010 at 10:34 PM
