1995 Mazda b2300 truck while running stalled and will not s
104,800 MILES • 4 CYL • 2WD • MANUAL
G9568
TRUCK WAS RUNNING FINE STARTED TO SLOW DOWN AT LIGHT AND TRUCK STALLED, TIMMING BELT BROKE, I REPLACED BUT STILL WILL NOT START?
Feb 16, 2010 at 7:00 AM
  • 75,988 POSTS
Did you put engine no.1 piston on its compression stroke/TDC and aligned the cam and crank markings and rotor pointing to no.1 cap tower if not the valve timing is off-
Feb 16, 2010 at 7:06 AM
G9568
Yes I did to answere your reply thank you but still not starting?
Feb 16, 2010 at 7:21 AM
  • 75,988 POSTS
Are you getting spark and the correct fuel pressure?
Feb 16, 2010 at 7:23 AM
