1994 Mazda b2300 balancer
1994 MAZDA B2300
ANAYAWALKER
Transmission problem
1994 Mazda b2300 4 cyl Two Wheel Drive Manual
directly behind transmission before first universal joint w/ a rubber center...can you name this part andtell me what it does and where I can buy a new one?.. THANK YOU!
Mar 20, 2010 at 7:09 AM
KHLOW2008
  • 41,814 POSTS
Hi anayawalker,
Thank you for the donation.
If you are referring to the item that is for hanging the propeller shaft, that is known as the shaft mounting.
Item should be available at your local parts store.
Mar 20, 2010 at 8:24 PM
