1994 Mazda b2200 clutch master cylinder
1994 MAZDA B2200
160,000 MILES • 4 CYL • 2WD • MANUAL
ARTY1122
i just replaced my clutch master cylinder and i am unable to get the air out of the system after bleeding the line where the slave cylinder enters the trans. The clutch has no pressure, it is free floating. why can't i get the pressure built up.
please advise
Feb 5, 2009 at 1:43 PM
Try bleeding the clutch master cylinder then the slave/servo-if it continues-recheck the master cylinder-Do you have any leak between the master cylinder and slave?
Feb 5, 2009 at 1:54 PM
ARTY1122
I do not have any leaks in the system from what I can see. The only place I have been bleeding the system is at the slave cylinder. How would i do it at the master.
Feb 5, 2009 at 11:53 PM
Crack the line to it -same way as the slave to bleed it-if continues replace it
Feb 6, 2009 at 3:43 AM
