1993 Mazda b2200 not starting
1993 MAZDA B2200
DERWIG61H
Engine Mechanical problem
1993 Mazda b2200 4 cyl Two Wheel Drive Manual
we have had the carb rebuilt, we have replaced the fuel pump, we have spark at the engine but it will not start, it turns over and thats it.
Sep 23, 2010 at 8:08 PM
Have you tried starting fluid thru the carb and the fuel pump producing the correct fuel pressure. If the cylinders are getting fuel and there's spark-best check the valve and ignition timing
Sep 23, 2010 at 8:34 PM
