I have both the brake light and ABS dash lights on. I have bleed the brake lines. When I press the brake pedal, I get little to no brakes. I have checked the pads which are about 75 percent. The brakes would lock up while driving not sure why and no lights would come on. But once you pressed the brake pedal hard then everything would go back to normal. What could the problem be?? I am not sure if the Power booster needs to be replace or if the ABS system is bad.
Nov 30, 2008 at 4:15 AM
