1992 Mazda b2200 white smoke cumming from exaust pipe, a lo
129,000 MILES • 4 CYL • 2WD • AUTOMATIC
JERRYMAT
thick white smoke cuming from the tail pipe what causes this???
May 19, 2008 at 4:21 AM
  • 75,988 POSTS
Get it block and pressure tested to rule out a blown headgasket, cracked head/block.
May 19, 2008 at 4:24 AM
HVNLYMSNGR81
it could be that your oil rings need to be replaced, this will cause the oil to burn up, which will be why you are seeing white smoke coming out of the exhaust. i have this problem also, what does the motor sound like when you crank it up?
Jun 3, 2008 at 7:29 AM
  • 75,988 POSTS
White smoke indicates coolant is being burn in the combustion chamber- or from a transmission vacuum modulator that's leaking into the intake if it has this type of tranny and also being burn.
Jun 3, 2008 at 8:01 AM
