1992 Mazda B2200 white smoke cumming from exaust pipe, a lo
JERRYMAT
MEMBER
1992 MAZDA B2200
4 CYL
2WD
AUTOMATIC
129,000 MILES
Thick white smoke cuming from the tail pipe what causes this?
Monday, May 19th, 2008 AT 11:21 AM
MECHANIC
Get it block and pressure tested to rule out a blown headgasket, cracked head/block.
SPONSORED LINKS
Monday, May 19th, 2008 AT 11:24 AM
HVNLYMSNGR81
MEMBER
It could be that your oil rings need to be replaced, this will cause the oil to burn up, which will be why you are seeing white smoke coming out of the exhaust. I have this problem also, what does the motor sound like when you crank it up?
Tuesday, June 3rd, 2008 AT 2:29 PM
MECHANIC
White smoke indicates coolant is being burn in the combustion chamber- or from a transmission vacuum modulator that's leaking into the intake if it has this type of tranny and also being burn.
