1992 Mazda b2200 Oil Pressure
104,000 MILES • 4 CYL • 2WD • MANUAL
TPNELSO
When my truck is running at a slow idle the oil light flickers on and sometimes stays on until the engine rpm increases. Is the oil pump going bad, or is there a deeper problem? It just started doing it.
May 21, 2008 at 2:12 PM
  • 75,988 POSTS
Find the oil pressure sending unit remove it hook up an oil pressure gauge-if normal pressure replace the OPSU. If not could be the oil pump or engine bearings-
May 21, 2008 at 2:39 PM
