1992 Mazda b2200 Gas Guage error
1992 MAZDA B2200
105,000 MILES • 4 CYL • 2WD • MANUAL
SCOTTY41B
When I fill the tank full, the gauge only shows three quarters of a tank. Could this be a constant voltage regulator, and how do I locate it?
Sep 4, 2010 at 2:50 AM
BLUELIGHTNIN6
  • 16,542 POSTS
probably faulty sending unit in tank. will need to disconnect sending unit connector and test with ohmmeter. if tank is half full than ohm should be 29 - 37. almost empty it should be 103-117. almost full should be 1-5. if any reading is wrong than sending unit needs replaced.
Sep 4, 2010 at 5:47 AM
