1992 Mazda b2200 choke
125,000 MILES • 4 CYL • 2WD • MANUAL
JEFFMOO
I put a new carb on it but the choke won't come off even after it's warm. How do i fix this?
Sep 12, 2010 at 1:55 AM
MERLIN2021
  • 17,250 POSTS
If the initial adjustment wasn't set, then do this:
CHOKE (B2200 CARBURETED) Apply about 16 in. Hg to choke pull-off diaphragm. Lightly push the choke plate to closed position. Measure clearance between top of choke plate and air horn. If clearance is not .067-.085" (1.70-2.16 mm), bend lever on choke plate shaft until clearance is within specification.
Sep 12, 2010 at 7:40 AM
