1991 Mazda b2200 while changing gears the clutch stayed dep
1991 MAZDA B2200
JCNAVARRA
Drive Train Axles Bearings problem
1991 Mazda b2200 4 cyl Two Wheel Drive Manual
I was acclerating onto highway and while i went to change gears the clutch pedal stayed on floor board. After towing i went under the truck and found the piston within the slave cylinder was no longer there. I also observed the clutch fork that the slave cylinder was connected to felt like it was free or easily able to be rocked back and forth. I then checked and found my fluid level for clutch master cylinder was empty. I purchased the slave cylinder and was wanting to know what else i should check or replace. And if the clutch fork is suppose to have those attributes of play. And what are the steps to follow in repairing the problem.
Jan 4, 2010 at 9:30 PM
DOCFIXIT
  • 18,828 POSTS
Hi
May have a pressure plate failure. Try installing slave , bleed out air see if it works. if no then need to remove trans replace clutch assembly.
Let me know
Thanks for donate
Jan 6, 2010 at 1:03 AM
