1991 Mazda b2200 Door Mirror
136,000 MILES • 4 CYL • 2WD • MANUAL
CHEMGEO
How do I replace the passenger door mirror on a 1991 mazda b2200.
Jul 15, 2010 at 1:12 PM
BLUELIGHTNIN6
  • 16,542 POSTS
The mirrors can be removed from the door without disassembling the door liner or other components except on Navajo models. The mirrors may be manual, manual remote, or electric remote. If the mirror glass is broken, replacements may be available through your dealer or a glass shop. If the housing is cracked or damaged, the entire mirror must be replaced. To remove the mirror:
1.If the mirror is manual remote, check to see if the adjusting handle is retained by a hidden screw, usually under the endcap on the lever. Or if it is retained by a threaded trim nut. If so, remove the screw, nut or other remote assembly retainer.
2.Remove the plastic delta cover from the door window corner where the mirror is mounted. It can be removed with a blunt plastic or wooden tool. Don't use a screwdriver, the plastic will be marred.
3.Depending on the model and style mirror, there may be concealed plugs or other minor parts under the delta cover. If electrical connectors are present, disconnect them.
4.Installation is the reverse of removal.
Jul 15, 2010 at 1:28 PM
