1991 Mazda b2200 bleeding brakes
GARY HARP
Brakes problem
1991 Mazda b2200 4 cyl Two Wheel Drive Manual new miles
we have put new motor in this truck and now are down to brakes. have replaced master cylinder,clutch slave,brake pads,checked lines,bled lines, checked pin behind pedal,and can not get any pressure to pump up brakes what could be wrong?
Jun 3, 2009 at 11:26 AM
  • 31,937 POSTS
Hi there,
Start with bleeding the master cylinder, if you don't get any fluid from the ports, replace the master and bench bleed the new unit before installing, start here.
mark (mhpautos)
Jun 3, 2009 at 11:32 AM
