1991 Mazda b2200
1991 MAZDA B2200
BRONCRIDER90
Engine Performance problem
1991 Mazda b2200 4 cyl Two Wheel Drive Automatic
What should i do to get more compression on the motor cause it wont even start...
Mar 5, 2010 at 9:36 AM
SHAWN_GEBO
if your not getting enough compression to start i sudjest as a b2200 owner as well i would check the obvious head gasket,and check the valve stem seal, or you could also have bad piston rings that wore out your cylinders. over haul is deffinitly nessasary do a compression test if its got less compression in certain cylinders than it would be the rings
Sep 8, 2010 at 12:22 PM
CHRIS42012
[quote:0ba445c878="broncrider90"]Engine Performance problem
What should i do to get more compression on the motor cause it wont even start...[/quote:0ba445c878]
need new rings if you have no compression...
Sep 24, 2010 at 3:00 PM
