1990 Mazda b2200 running hot and smokeing
1990 MAZDA B2200
118,000 MILES • 4 CYL • 2WD • MANUAL
JORDAN32
when i start my truck up it smokes and then stops and after a little while it runs hot .i changed thermostat hoses ,plugs cap and rotor.still runs hot
Oct 27, 2010 at 9:52 AM
Check and test the radiator if its clogged and the water pump if both okay, try bleeding it if it continues -get it block and pressure tested
Nov 25, 2010 at 4:24 PM
