1990 Mazda b2200 hesitation..
1990 MAZDA B2200
16,000 MILES • 4 CYL • 2WD • MANUAL
PAVEMENTPOUNDINS10
i got a mazda b2200 for $500, the guy said the timing belt is stretched, he took the bolt out of the distributor adjuster hole, moved the distributor around passed it to compensate i guess, it hard to start and when it starts it sounds like it running on 2 cylinders sorta, when it gets warm it kinda stops, runs poorly, sounds like it is missing, what do i do, it is a nice looking truck and wanna save it, also said that he put plugs and wires in it...and it still acts up, oil looks good as does the coolant..
May 30, 2008 at 4:48 PM
LEGITIMATE007
  • 5,121 POSTS
the only thing to do is try to get everything back to normal fix his little distributer mickymouse rig. and then take a look at the timing belt . and replace . I don't know he's saying the belt stretched? whats that mean?, its been slipping timing? better look into it. maybe even a compression test . to check for possible damage to the valves
May 30, 2008 at 5:05 PM
