1990 Mazda b2200
204,000 MILES • 4 CYL • 2WD • AUTOMATIC
MATHIAS
engine runs fine when cold but when it reaches normal running temp..it shuts down..idles fine but when you put it in gear it shuts down...you can wait around 5 min it will go when you put in gear..then when it gets warm it shuts down
Jul 29, 2008 at 11:04 AM
  • 75,988 POSTS
Check the the coil's primary and secondary winding resistances and also check the fuel pressure then comeback with both readings this where we start.
Jul 29, 2008 at 11:09 AM
