1990 Mazda b2200
1990 MAZDA B2200
204,000 MILES • 4 CYL • 2WD • AUTOMATIC
MATHIAS
engine runs fine when cold but when it reaches normal running temp..it shuts down..idles fine but when you put it in gear it shuts down...you can wait around 5 min it will go when you put in gear..then when it gets warm it shuts down
Jul 29, 2008 at 11:04 AM
Check the the coil's primary and secondary winding resistances and also check the fuel pressure then comeback with both readings this where we start.
Jul 29, 2008 at 11:09 AM
