1989 Mazda b2200 Timing
192,000 MILES • 4 CYL • 2WD • MANUAL
PSYCHOJOE57
hello and thanks , with a high mileage engine should the ignition timing be set slower or faster to compensate for wear.. I have heard to try but dont really know it calls for 6 deg BTDC from factory any thoughts on this is appreciated... Marshall
Apr 11, 2009 at 11:29 AM
  • 75,988 POSTS
You can advance the timing but make sure there's no pinging if so back off a bit
Apr 11, 2009 at 11:54 AM
PSYCHOJOE57
Thanks for the input.....so advance would be the way to go I will try it out and see if it helps ...
Apr 11, 2009 at 12:37 PM
