1989 Mazda b2200 starting
TAMMYSCHELL
Engine Mechanical problem
1989 Mazda b2200 4 cyl Two Wheel Drive Manual
the truck has power butt won`t start the starter is good had it checked the truck will not crank over it was fine turned it off and wouldn`t start back. It will pull start and have full power
Please help
Tammy
Feb 21, 2010 at 12:35 PM
  • 75,988 POSTS
No cranking:
Could be the starter, starter relay, park and neutral switch/clutch switch and ignition switch assuming the battery and connections are good-if it doesn't apply disregard it
Feb 21, 2010 at 1:17 PM
