1989 Mazda b2200 engine stalls
135,000 MILES • 4 CYL • 2WD • MANUAL
RAYMONDVIERA99
my truck stalls when I am coming to a stop. If I use the E brake or the brake pedal it wants to die, but I can feather the gas a little and it will idle again. Now if I am going in R and brake truck is fine. I thought it was the brake booster or hose so i replaced both. thought it was the carb replaced with a used one. I have spent my last dime and the problem is still the same. I have even asked a friend who is ase master teck. and he does not know please help I need truck to go to work. thank you
Feb 17, 2009 at 6:24 AM
  • 75,988 POSTS
Check the PCV and EGR valves
Feb 17, 2009 at 6:43 AM
