1989 Mazda b2200
1989 MAZDA B2200
ESTRADA11414
Engine Performance problem
1989 Mazda b2200 4 cyl Manual
i just bought a 1989 mazda b2200 5 speed a few months back i recently took it to get smogged and it failed three times it runs very good all i was told is that it is running rich and that it has a crack in the crank shaft valve i have replaced the catylitic converter replaced all filters all spark plugs & wires vaccuum hoses dont know what to do to correct this problem i really need to know if this is fixable
May 27, 2008 at 11:09 PM
Possible causes include a bad O2 sensor, excessive fuel pressure (bad fuel pressure regulator or plugged return line), leaky fuel injectors, dirty air filter or restricted air inlet, or a defective coolant sensor that prevents the engine management system from going into closed loop mode.
May 27, 2008 at 11:16 PM
