Hey there, Im workin on a B2200. The current issue is Coolant being burnt off thru the exhaust. Classic white sweet steam. The tests i've performed are : Rad pressuering test, Holds pressure, And not gaining pressure from compression leak. Check plugs, #3 being suspiciously clean, But Cyclinder NOT . Pressureing up each cyl. on TDC watching for bubbles from rad, None. Compression test All 4, normal and no dramatic pressure loss. Visual inspection of each cyl. with a scope, normal. The coolant is building up in the exhaust somewheres and burning off when the motor starts burning. I suspectded head gasket at first, but every test and inspection ive done proves me wrong. I am keeping rad pressure toped up with a tester and leaving it sit for a few hours, then im gunna check the cylynders agian for leakage, and i am also going to pull the exhaust manifold off to see...? Anybody have this issue? any answers? HELP LOL
Jan 14, 2010 at 10:21 AM
