1988 Mazda b2200 Clutch pad drops down and wont come back u
190,000 MILES • 4 CYL • 2WD • MANUAL
AJBABA
When clutch is pushed I can only change gears one time. The clutch pad sits down and wont spring back up. Car at this point is unusable. How do I exactly fix this? is it a spring problem? HELP !!!
thanks!!!!!!
Sep 10, 2008 at 4:27 AM
ASL3762
  • 6 POSTS
yes it may be a clutch spring problem check that out an if your spring is ok, check your clutch master cyclinder
Oct 14, 2008 at 6:26 PM
TOMKAT
I have a 1990 mazda b2200 with the same problem. the clutch pedal would suck straight down to the floor. turns out it was the clutch slave and master cylinders. cost me about 400 parts and labor on a sunday in the middle of no where. thats with a tow as well
Nov 8, 2008 at 11:42 AM
