1988 Mazda b2200 CLUTCH
1988 MAZDA B2200
13,000 MILES • 4 CYL • 2WD • MANUAL
BULLITTSDAD
I FILLED THE MASTER CYLYNDER FOR THE CLUTCH WITH FLUID BUT STILL HAVE LITTLE OR NO CLUTCH, IS THERE A WAY TO BLEED IT?
Sep 5, 2008 at 8:03 PM
2CARPRO JACK
  • 11,533 POSTS
should be a bleeder on the slave cylinder on the trans.Works just like bleeding brakes.Might want to pump the pedal alot first to try to purge any air that is trapped in the clutch master cyl.Then go to the slave cyl
Sep 6, 2008 at 1:32 AM
